Click an existing dimension to reference it as a parameter doesn't work.
a_paez7DZM7
Observer Observer
a_paez7DZM7
Observer
Observer
After the last update, the feature that allows to click an existing dimension to reference a new one dimension doesn't work.
jhackney1972
Do you mean this process?  If so, try restarting your system if you have not since the update.
John Hackney, Retired
a_paez7DZM7
Observer
Observer
Yes. Is that process. I just find out that it only happens when working on the Form mode sketch tool. In the other modes it works as always.
jeff_strater
that is by design.  Sketches in Form mode or Base Feature mode are non-parametric.  Non-parametric sketches do not support parameters at all.
Jeff Strater
Engineering Director
a_paez7DZM7
Observer
Observer
Thanks for clearing that up.
