02:21 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello i have a circular band that i have made using parameters and i have added a hole 2mm at one point. I would like to pattern this hole around the band using parameters so when i update the size of tube the number of holes increases or decreases accordingly. Is there an equation that can calculate that? Ive tried to use degrees but maybe im writing the parameter incorrectly.
Also im aware circular patterning needs a whole number so im curious if its possible to have a fuction that rounds down/up to the nearest whole number.
Thank you! Been messing around but my maths is rusty.
