Changed post processor screen use.
spancheau
spancheau
The post processor selection screen has changed. I cannot access the processor I want to use. When I select the post , I get a message box  that says "Use posts from fusion 360 library?"  It then tells you that these are automatically updated. I cannot get past this to 0pen the selected post processor.
Scott
seth.madore
When you click on the post processor, you are prompted on where you want to save the post. Personally, I prefer to save a file to a local drive or the cloud (this prevents overwriting of the post when I know it's running perfectly). So, you are going to either:
A) Turn on Cloud Libraries and save the post to that location
B) Create a folder on your computer, link that in the Library and then save the post to that location on your computer.
I'd recommend option "A", as that will allow you to post your code from any computer you log into.
Seth Madore
seth.madore
To link a local folder to your Post Library:
Seth Madore
spancheau
Thank you Seth. The way this was worded as a question with an option, I thought I could let Fusion do the auto  updates and there should be a way to just accept that and open the post I wanted. I will do as you suggested.
Thanks again,
Scott
