I made a very simple hexagon design because I wanted to test something out. However, the X/Y dimensions are doubled when I export the design to a STL and open up in either of my two slicers (Prusa and Cura).
- I created the object using mm (X= 31.25 mm, Y = 36.66 mm, Z = 6 mm).
- I tried all three methods to export/save the object as an STL.
- I open the file in Prusa or Cura and the object dimensions are now x= 63.5 mm, Y = 73.32 mm, Z = 6 mm.
- I even started over from scratch to recreate the object and still got the same result.
I am confused on this one as it has not happened before.
Yes, I know I can resize the object to the correct dimensions in the slicer but this is still an annoyance that I don't want to have to deal with in future files.
Thank you for any help.
