Change weight unit.
Change weight unit.
petrol_junkie
Message 1 of 11
Change weight unit.
petrol_junkie
Hi.
Been searching the forum but  not really finding an answer to what I´m looking for.
Is there any way to change the unit of showed mass in the property info. The scientific version just bugs me, especially when you
have a model that actually has a couple of kilos to it 🙂
And of course without changes the units of the whole part / assembly.
// P-J
Because we all need a bit of Sweden in our lifes....
Replies (10)
Message 2 of 11
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @petrol_junkie
Thank you for your posting!
The properties units are following to Document setting option. If you change it to "M", you can see it with KG.
For your reference, the Material Unit Display option represents the material physical properties in Manage Materials. (Modify -> Manage Materials)
Hopefully, This will help
Many thanks,
Ahreum.
Message 3 of 11
petrol_junkie
HI @ahreum.ryu.
Thank you for the swift response.
The solution you are mentioning changes the units of the document, which means that my dimensions needs to be inputed in Meters... and that´s not really useful to be honest with you.
Or are saying that I need to change back and forth for every time I want to check the weight of my design?
Best regards:
P-J
Message 4 of 11
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @petrol_junkie
Yeah..Smiley Sad I understand that it's a bit inconvenience. In our IdeaStation, Someone posted the same issue. Let's vote it to be accepted as a future consideration.
Also, you can communicate with Product manager through the Ideastation.
Thank you for your understanding!
Many thanks,
Ahreum.
Message 5 of 11
petrol_junkie
@ahreum.ryu
Thank you once again....  I have voted and posted a reply in the Idea Station thread you linked to.
Really looking forward to more of theese small but really useful enhancement in F360, they are really needed.
// P-J
Message 6 of 11
yanouk73
This is a problem in the drawing table and anywhere else that use the weight.
It's actually show a scientific value in grams in my case, 1.123456E+9grams
I what to have the control to adjust the units per component or minimum per file.
Yan
Message 7 of 11
yanouk73
Yan
Message 8 of 11
dusan.naus.trz
Each customer asks how to change the display in properties with g units per kg and keep mm. And they also ask about the units in the drawing? Is it a bakery program? Or for industry? I'm not even a goldsmith. When will it be possible to change? It spoils sales.
Message 9 of 11
manuel.fr
i don't understand this too, this makes absolutly no sense to me.
as long as i work, thats about 13 years, it was always mm and kg in germany in the industry and automotive sector. And never mm and g. No one wants to know how many gramm a base frame or a part wheigts.
It was and always will be kg.
it should be changeable in fusion... at this state its not usable.
Message 10 of 11
hauver.1
Wanted to chime in and keep this alive. I work as an engineer and have never used or seen anyone use ouncemass as a weight/mass measurement. Please give us the option to customize our units.
Message 11 of 11
FLEXXFORM
Community Visitor
Community Visitor
Over six years is plenty of time to correct such an elementary detail Autodesk has been pointed to repeatedly... really wish this would finally be solved 🙄
