Change length of fastener (from library)?
tomae
Message 1 of 22
tomae
Is there an easy way to change the length of a fastener I added from the fastener library?
I added a 7/16-20 Ansi Socket Head Cap Screw and the length I needed, 1.125", was not available from the list.  I added a 1" long screw instead.  I want to edit the model screw to add the additional .125" to it.  I don't see parameters that I can change for that.  How would I go about doing that?
-Tom
Accepted solutions (3)
Replies (21)
Message 21 of 22
tomae
I didn't realize that.  They should be paying you 🙂
-Tom
Message 22 of 22
chris
Is there no way to add the fastener length option to the fusion library so its selectable from the insert fastener dialog?  the methods shown ive been playing with and its a royal pain.  I would think that adding the lengths you may use frequently wouldn't require all that much work.  is there an accessible database somewhere where this can be done?
Thanks in advance!
