Chamfer on Corner with Two Components
ole.ziessler
ole.ziessler
Hallo,
I would like to add a Chamfer to a inside Corner where two Components meet. The Chamfer tool however only works on a complete edge. Any tips, tricks, work arounds to realize a corner chamfer as if it was one body. Combining and splitting seems too tedious. See Photos below as an example
jeff_strater
Fusion does not support "partial Chamfer/Fillet".  You will have to split the body of the component on the right, using the plane of the component as the splitting tool, apply the Chamfer, then Combine the bodies again.  I'll demonstrate with a video soon.
Jeff Strater
Engineering Director
jeff_strater
here are two approaches.  The first is just illustrating the basic idea.  The second ends up with better geometry:
Jeff Strater
ole.ziessler
thanks for the quick reply and assistance. Combining the two bodies, using chamfer and then splitting them again also works. Your version is however some what better due to not having to rename alle components.
