- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using a chamfer mill and the 2D chamfer toolpath, an inner chamfer doesn't generate a toolpath.
I first created an outer chamfer, which generates a path. I then duplicated this, and selected an inner contour instead, and that toolpath doesn't generate.
The project is attached. There's also a video here.
In brief, an outside chamfer generates just fine, but an inside chamfer generates no toolpath.
Interestingly (?) I had a problem with Chamfer toolpaths two years ago, where not having a defined a "body" in the setup resulted in truncated chamfer toolpaths. This time, I have defined a "body" but it still doesn't work.
