Chamfer and taper angle feature broken
I used to be able to extrude virtually any shape with a negative taper angle up all the way to a point without error messages and now it simply will not perform this function. I did this exact operation 2 weeks ago on a specific drawing and it worked fine. Attempting to do the same basic process again today, even using the same sketch or very basic shapes, and it just will not work. I just keep getting error messages to change the angle shape or distance. Its like I now have to know the exact height to match the angle to taper to a point. Did Fusion update or change something? I am literally performing the same exact operation that worked previously with the same exact sketch but now it won't go.
jhackney1972
Works OK on this end.  Please Attach you model so the forum users can take a look.  Open you model in Fusion 360, select the File menu, then Export and save to your hard drive.  Attach it using the Attachments section below in a forum reply.
John Hackney, Retired
jhackney1972
Since you have not shared your model, I will share one that demonstrates, what I think you are describing, works just fine.  If I missed something, please let me know.
