Center point offset in projected plane.
modijenish10
Observer Observer
modijenish10
Observer
Observer
when I draw the sketch on projected plane, center point is automatically offset as shown in video. I would like to know the reason.. and solution for the same.
g-andresen
You must first enter the geometry of your component into the active Sketch. Then you can e.g. bind a new hole (circle) at the centre of the hole in the component.
Deactivate the grid. Then you get a better orientation on the reference part.
günther
TheCADWhisperer
@modijenish10
That geometry looks a bit rough.  Do you have a reference of what you are attempting to model?
If you use the BORN Technique as much as possible and practical there is seldom a need to create workplanes.
modijenish10
Observer
Observer
Thanks for the solution..it get corrected when I turned off the grid.
