Center of mass/gravity in a drawing
sutherland-
Message 1 of 9
sutherland-
Dear community,
I would like to know how is it possible to show Center of Mass/Gravity in a technical drawing?
Example can be seen below:
Best,
Kritzz
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Replies (8)
Message 2 of 9
sutherland-
The only way I can see how to overcome the question, is placing the Center of Mass in the design workspace , then manually measuring it form the midpoints of the design, which is really time consuming and not handy.
Best regards,
Level  sutherland-
Member
Message 3 of 9
jhackney1972
Take a look at this Blog Article and Video to demonstrate the process.  The article also mentions another article which talks about placing the center of mass in the model.  It is a manual process but these will speed the process.
John Hackney, Retired
Message 4 of 9
sutherland-
Tried your solution, but my point sketch is grayed out in the drawing workspace.
Best regards,
Level  sutherland-
Member
Message 5 of 9
jhackney1972
I am experiencing the same problem.  Something is very different with the way Fusion 360 handles the position of points in the drawing environment since I recorded the Blog video.  It would seem it cannot handle the sketch if it is moved off of the plane on which it was created.  I am working on a different workflow and if I can find one, will update my blog.  I will also come back to this post and update it also.
Message 6 of 9
jhackney1972
Since Fusion 360 no longer will show a point in a drawing view that is "not" on the original plane of creation, I have come up with another method.  The process is outline in the video below.  I will be updating my Blog article and video as soon as possible.
(view in My Videos)
Message 7 of 9
sutherland-
It worked, awesome, thanks!
But again, it is a bummer that Fusion 360 does not have it as a default feature, since this is quite crucial for DFMA.
Best regards,
Level  sutherland-
Member
Message 8 of 9
RLShute
Observer
Observer
I would like a simple solution so that I can use it with my High school Freshmen.  The system based on creating a new componet and sketch points in required views is to diffcult for the majority of them.   I know if I forced them to do it that way it would turn new Fusion users off from the product.
The reason I care is that students are designing and building compresses air rockets.  In doing this I want to compare the center of mass to the center of pressure to help them design rockets that do not tumble in flight.   I hope Auotdesk see this and design a way to transkfer the center of mass from the model to the drawing with the touch of a button.
Message 9 of 9
Matt_Finish
Has this been properly solved since this post's creation? (ideally imputing COM Symbol into a drawing)
