center lines disappearing
MariusBaard
Message 1 of 8
MariusBaard
I have made a part and only afterwards used the bend from flat to bend 2 hooks 45 deg.
Now that I go to flat pattern the center lines is missing.
That should not happen
Accepted solutions (3)
Replies (7)
Message 2 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @MariusBaard
Can you share the file so I can take a look?
Karina
Message 3 of 8
MariusBaard
Hi Karina
I will, as soon as I can get into Fusion. It keeps on hanging on start.
It sounds like a network problem.
Should Fusion not still start but in offline mode if there is no network?
Message 4 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @MariusBaard
Fusion should start in offline mode if you have no network connection, yes. Is it working now?
As for your file, @ryan.bales and I have not been able to reproduce from scratch. I'll log this with the development team and they can have a look. It might be specific to your file.
Thanks for reporting this - have you seen it anywhere else?
Cheers,
Karina
Message 5 of 8
MariusBaard
Hi Karina
We seem to have a problem with our network, I have allowed it through the firewall but we still had to do the comparability thing to windows 7. I am running windows 10
No I have not seen it anywhere else as this was the first time I used this function in Fusion, have used it in Creo a lot of times before.
But look at all the other parts in the design with bends, they do the same thing
Message 6 of 8
nikhil.naikNLKQG
Hi @MariusBaard
Analyzed the part file you provided and I could reproduce the issue with simplified part file. It appears, for this type of bend, the bend line position - Center is causing some issues. While this problem will further be drilled down, here are some quick workarounds -
1) If bend relief is not required - Either turn off the checkbox on dialog or extend the bend line on both sides.
2) If bend relief is required - Use separate bend lines for creating two bends or set bend line position to Start.
Please refer to the video attached, simplified part file & your part file with workaround applied, for detailed information. Hope it helps.
Message 7 of 8
MariusBaard
Hi Nikhil
Thank you.
I will try your solution later when I have a minute to spare.
Kind regards
Marius
Message 8 of 8
MariusBaard
Hi Nikhil
Separate lines did the trick, thanks.
But please work on the possibility of doing a single line as it saves time, and time is money
