Canvas Not Adding to New Component
john_shumelda
Message 1 of 17
john_shumelda
When I create a new component and try to import a canvas to that component (with it selected) it only adds the canvas to the parent folder of the project rather that that specific component. How do I add a canvas to a new component for organizational purposes? I am using the consumer / personal version of Fusion 360.
Replies (16)
Message 2 of 17
jhackney1972
The only method to have a Canvas Insert to stay related, and fall under, a certain component is to insert it into an External Component which can either be created in the assembly or Inserted into it from the Data Panel.
John Hackney, Retired
Message 3 of 17
davebYYPCU
Not so.
Activate the Component.
I selected the component Origin plane to put it on.
Message 4 of 17
g-andresen
The canvas only appears within a component if it is active and the reference surface (origin, plane, face) is within this component.
Günther
Message 5 of 17
john_shumelda
Hello! Thank you all for your responses. From the information I have been able to gather your answers make sense.
For some reason it still doesn't seem to be linking the Canvas to the Component when I have it selected. I have included a screen recording to show you what I mean. Please let me know what you think might be the issue.
Message 6 of 17
davebYYPCU
Refer to my picture,
Activate the component, and show Component Origin, hide the file Origin.
Might help....
Message 7 of 17
g-andresen
Even if the file origin is disabled and partially overlaps with the component origin, it can be selected.
If you want to be sure, you have to open the origin folder first and then select a layer directly.
(view in My Videos)
@jeff_strater
I think that should not be, right?
günther
Message 8 of 17
john_shumelda
Hello!
Thank you for all the advice and your help with figuring this out. The video illustrated well for me that there is a very small area in which I may click on the Origin with the Origin of the Sub Component being viewed. A few pixels in either direction could connect the Canvas to the Parent rather than the sub Component accidentally. After opening up the folders for the Origin of the sub Component, making the Origin visible and then opening the file structure of the  Main File I could see that this slight deviation of where I click dictates to which Origin the Canvas is linked.
It still seems to me that this function is working much more seamlessly for others as they can just select the relevant Component and import the Canvas directly to that Component rather than opening the Component Origin, Making it Visible and then placing it.
This solution has solved my problem. Thank you again!
Message 9 of 17
davebYYPCU
If your origins overlap, click drag / move the component away,
Capture position, Insert and Delete the Capture position..
Seems to me the correct plane is the brightest, File Origin is dimmed, with eyeballs off, it was not selectable for me, Windows 10.
Might help....
Message 10 of 17
g-andresen
Nevertheless, in my opinion, a deactivated file origin should not appear in a selection menu.
günther
Message 11 of 17
huxueqing112
Observer
Observer
Hi, how to show the popover in which plane can be chose?
Message 12 of 17
marlolwsk
Community Visitor
Community Visitor
i would like to know that too
Message 13 of 17
jhackney1972
If you are referring to the box, that appears with the origins planes selection, this can be displayed in most any operation by hovering your mouse cursor over whatever you want a list of and hold your left mouse button until the list appears.  The list will contain all the entities under the cursor when you held down the left mouse button.
In the Animated GIF, I am hovering my cursor over numerous faces.  As I hold down my left mouse button, the list of these faces appear.  I can move between them and they highlight.  I can then left click on the one I want.  It works is most all selection operations.
Message 14 of 17
marlolwsk
Community Visitor
Community Visitor
Thank You soooo much!! You are Awesome!
Message 15 of 17
m_vasiliauskas
Community Visitor
Community Visitor
I had the same issue. For me when you create a new project, the ORIGIN is disabled, and when you create NEW COMPONENT the ORIGIN of new component is also DISABLED. Then when you do insert CANVAS you have to select a plane, and I guess because of the hierarchy (and because both origins are disabled), the higher origin is selected. All you have to do is enable the new component origin and then canvas goes under it.
Message 16 of 17
sibinaa
Community Visitor
Community Visitor
Thank you so much for your help. I was struggling to figure out why the canvas didn't go to my new component.
Message 17 of 17
dr_deedledum
Community Visitor
Community Visitor
This was definitely the best answer haha
