Cant save file. "Newer Version of design available"
carriemerriam
carriemerriam
This is the second file I have had do this in 2 days. The "add description" dialogue box appears different than it normally does and won't actually let me hit ok to save. I can still save as normal in other files.
There is no newer version than the one I'm working in. I have tried clearing my "Q" folder and the UploadQueuedFileList.xml  in case the file is stuck in the queue as is recommended on the Autodesk Website. I also made sure that me license is up to date.
Thanks in advance for any help.
rhudaynath
Hi @carriemerriam
Sorry to hear that you are facing this problem.
In case you are able to reproduce the problem, can you please share the log files, it will help us to investigate the cause. Please refer How to collect the Diagnostic Log Files for Fusion 360
A small video of your workflow will help us to understand your experience.
Thank you!
Rhudaynath
Software Engineer
