Cant mill with the CNC3 -3018 Pro
Im trying to mill my first test piece... I'm using Autodesk Fusion 360  with CNC3-3018Pro and every time I get to the tool screen I get the following screen... I'm running Windows 10 ... any suggestions
jhackney1972
It has been suggested that there is a display error in the Preview Features, Tool Library.  Remove the check from the box shown, restart Fusion 360 and try your process again.
John Hackney, Retired
Did not work, but it did work on my apple ... gonna try it on the apple
Thai is how I solved it ... fusion is very buggy on windows 10 ... not just the tools ... great concepts not all the bugs worked out ... so I used Fusion 360 on my MacBook ... worked perfect, but the is no G-Code (Camel) so I could learn another program or I emailed the g code to self ...loaded it on the camel on my windows machine and after some fine tuning it worked .... a lot of work for a 6 x 6 in piece of acrylic with a 3 inch hole...roccomendation.. If you are just starting test a couple Cads and you can get other G-code translates ...I just didn't want to relearn everything ... but I would use Sketchup for small milling ... very simple and stable
