Cant get screencast recorder.
So for about a week now i have been trying to get screencast recorder to help you guys help me but it just says theres a problem with the domain or something. Is there another way of downloading it?
TheCADWhisperer
Thanks, downloaded but it acts like a totally separate app which is fine. The file, share, launch screencast recorder is still throwing the same error, but if i open it outside of fusion 360 it seems like it will work.
g-andresen
how to start SC from the app:
günther
Phil.E
Couple things:
Screencast is a separate application as you have noticed. You can record anything with it. When installed side by side with Fusion it will start up when Fusion starts up.
There is a bug I'm aware of that if Screencast is shut down while Fusion is running it may not start from the "share" menu. Remedy: Restart Fusion.
This could also have been the result of installing Screencast while Fusion is running, I haven't tested that exactly, but it might bring the same result.
To be 100% sure, have you tried restarting your computer lately? Give that a try, then start Fusion, then try to start Screencast from the File > Share menu. Let me know how it goes.
Phil Eichmiller
Software Engineer
Quality Assurance
