Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Cant convert large DWG to fusion model
ned.morris89
Message 1 of 11
ned.morris89
I need to get a large DWG into fusion. Its 272mb.
First I tried by just uploading directly to fusion, but it hit the 1hr timeout.
So then I went into A360 and uploaded it to my account successfully. But now when i try to open it in fusion, it keeps timing out. https://a360.co/39Rlxpv
What are my options here.
Ned
Replies (10)
Message 2 of 11
jhackney1972
You could share the A360 upload so other forum users can give it a try.
John Hackney, Retired
Message 3 of 11
jeff_strater
can you describe what is in this DWG?  Is it 3D geometry, a 2D drawing?  Or, something else?  If this is nearly 300MB of 2D data, you will not have much luck.  Fusion will try to load this into a sketch, and that sounds like it will produce a massive sketch that is guaranteed to cause you problems.
Jeff Strater
Engineering Director
Message 4 of 11
ned.morris89
It is a 3d model with LOTS of surfaces. Its a part model of a vehicle.
Here is the link to the model https://a360.co/39Rlxpv
Message 5 of 11
jeff_strater
this may just be too much data for the translators to handle.  Also, translating it will be just the start.  I highly suspect Fusion itself will not work well with this much surface data.  Is there a subset of this design that you can work with?  Sorry not to have a better answer.
Jeff Strater
Message 6 of 11
ned.morris89
Hmm not really. I dont actually need to work with it...I just need to review it, do some measuring etc etc and give feedback to my modeller.
Message 7 of 11
ned.morris89
Would a .step file be better?
Message 8 of 11
jeff_strater
I suspect not.  I think the problem is the sheer size of the data, not the format.  If all you need to do is review it, I would try loading it into viewer.autodesk.com.  I started that, but it is still running.
Jeff Strater
Message 9 of 11
ned.morris89
Trying now. But its been processing for a while now.
Message 10 of 11
ned.morris89
So it loaded the 2d version. But when I click on "3d view" i get a processing failed error
Message 11 of 11
jeff_strater
same here.  Might be worth trying the STEP version, if you do have access to that.  No guarantees, but worth trying.
Jeff Strater
