Cant allign components in designs
HenryDara
Message 1 of 12
HenryDara
Im trying to find out what I have in my timeline that would prevent me from alligning components using the Allign command. If I insert the components early in the timeline they allign without any problem. When I try to allign later in the timeline I get...
Error: No alignment suggested by geometry could be found
Possibly related to this is that every joint I create later in the timeline creates itself with a warning...
Warning: Compute Failed some positions cannot be resolved due to joint conflicts.
Though it creates the joint, and keeps things together, its just not happy with something ive done.
I can share the design in PM only
Thanks...Henry
Any resource, or tips to figure this one out would be appreciated.
Replies (11)
Message 2 of 12
ryan.bales
Autodesk Support
Autodesk Support
Really like you said, someone needs to see it. Its way too abstract in text form.
Can you share it with me? I'd be happy to take a look.
Ryan Bales
Fusion 360 Product Support
Message 3 of 12
mda
Was a solution to this problem ever found?  I've been working on an assembly with no issues and suddenly the align command starts giving me the same error message.  It's making my work very difficult.
Message 4 of 12
Personal_Playground
same issue...out of the blue the align command no longer functions and no obvious reason.
Message 5 of 12
jhackney1972
Can you attach your assembly where you are seeing this issue?  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Message 6 of 12
jonvolk
Observer
Observer
Is there a solution to this? I have the same problem where all align operations fail and all new joints generate a warning.  Is there an email address I can send the project file to? There paid for sub-components that I do not want publicly available.
Message 7 of 12
TrippyLighting
In an assembly with components, the Align function (perhaps followed by a position capture feature) is not a proper method for permanently positioning parts. That's what joints are for!
In a mechanical assembly such as the one in your screen capture, I would not expect to see a position caputure feature in the timeline.
Message 8 of 12
TheCADWhisperer
@jonvolk
Can you Attach a dummy assembly that exhibits the same behavior as your proprietary data so that someone can demonstrate Joints?
Message 9 of 12
jonvolk
Observer
Observer
There are dozens of position captures and joints in this design. In addition to align failures and joint warnings, it will no longer capture position. Upon moving a component, if capture position box is check, that fails. If the component is moved without checking that box, the capture position buttons are absent from the menu bar.
Message 10 of 12
TrippyLighting
@jonvolk wrote:
There are dozens of position captures and joints in this design ...
Then I suggest you start from scratch using proper assembly techniques 😉
Message 11 of 12
jonvolk
Observer
Observer
Walked it back to a bulk merge of subcomponents to a single parent that had a warning. Deleted the offending warning, then moved that single component back in to the parent as one operation. Then it magically worked <shrug>
Message 12 of 12
TheCADWhisperer
There is no such thing a magic.
There is, however, a logical explanation.
