- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am experiencing erratic behavior with sheet metal. Here is my workflow:
- From a sketch I extrude a surface using one or more tangential arcs. I am extruding perpendicular to the sketch. The surface only curves in one direction.
- I then might using other surfaces to split faces of that extruded surface to arrive at a surface that I want to convert to sheet metal and unfold.
- I thicken the surface.
- I use Extrude to create a small flat tab to use as the stationary face for unfolding.
- I convert to sheet metal.
- I then try to unfold. SOMETIMES this has worked fine. And now, it fails consistently. Fusion will not allow me to select the stationary face. It does not highlight.
The above workflow has worked completely fine SOME of the time. And in my design I cannot do even the simplest unfold. I have tried using a new sketch with new geometry. I have tried making a component of my surface first, and then thickening and turning it into sheet metal. I see a Sheet metal rule show up in the component. Fusion seems to connect the thickness and match it to a rule. But I cannot get past the unfold step.
What do I do? If I cannot get past this problem then I have a design in an inconsistent state and I cannot move forward with any confidence. I will pay for tech support if necessary.
