Cannot start Fusion 360
Fusion doesn't open and the window stops responding when I try opening it without internet access. A quick resolution would be appreciated.
Thank you for the help in advance.
Shubham
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for your posting!
Before disconnecting Fusion 360, have you changed Offline mode?? If not, you should reconnect to the internet. This is how to work in offline mode.
Here is the similar issue.
https://forums.autodesk.com/t5/fusion-360-support/fusion-360-does-not-start-offline-if-not-connected-to-internet/td-p/6770157
If I misunderstand, please let me know!
Many thanks,
Ahreum.
