Cannot see Add-in after installation
Ex_Machina_Engineering
Message 1 of 18
I just downloaded the Mesh Intersect add-in, installed it and I cannot see the command button where it is supposed to be. I cannot even find it in the Scripts and Add-ins dialog.
Is this a know issue?
Replies (17)
Message 2 of 18
ryan.bales
Autodesk Support
Autodesk Support
Hi @Ex_Machina_Engineering
You might have to back to add-ins and rerun it. Make sure if you do that you select "run on startup" or you'll need to do this each time.
I just had to do this after the last update to the add-ins i have as well.
Ryan Bales
Fusion 360 Product Support
Message 3 of 18
Okay, but I can't even see it there. Like it was never installed
Message 4 of 18
ryan.bales
Autodesk Support
Autodesk Support
You might want to navigate to the folder location for Add-ins. If they are there, that would be a different issue. If not you may need to go reinstall them.
Are you on a Mac?
Ryan Bales
Message 5 of 18
I'm on a Windows 10 PC. And to be honest, I can see that my add-ins are stored in 2 different locations...
However, I have Mesh Intersect in one of them and I copied the folder in the second one.
I have active add-ins from both locations
Message 6 of 18
ryan.bales
Autodesk Support
Autodesk Support
I noticed that too. Is it working after the copy?
Ryan Bales
Message 7 of 18
Nope. Still can't see it
Message 8 of 18
ryan.bales
Autodesk Support
Autodesk Support
They should be there, i'm thinking that you may need to restart your computer and give Fusion a fresh boot.
Ryan Bales
Message 9 of 18
Done that too a couple of times...
Message 10 of 18
Add-ins didalog.pngHere is a screen shot...
Message 11 of 18
ryan.bales
Autodesk Support
Autodesk Support
Have you tried adding it via the green + sign? you should be able to select the folder since it exists.
Ryan Bales
Message 12 of 18
Error Message.pngThat's what I got now
Message 13 of 18
ryan.bales
Autodesk Support
Autodesk Support
That sounds like the add-in did not install properly.
Ryan Bales
Message 14 of 18
So, what do we do now?
Message 15 of 18
ryan.bales
Autodesk Support
Autodesk Support
We could try a uninstall with the cleanup tool. It might mean navigating to the folder and deleting any remaining folders then reinstalling Fusion and then the add-ins.
I've seen a few with Mac where they don't load well but i've not had or seen any issues on Windows yet.
Ryan Bales
Message 16 of 18
Actually, I went over to Github and downloaded the same add-in from the developer's page. It actually has slightly different functionality which I find even better. Added through the green "+" button and it worked fine. Don't know what was going on with the version from the app store.
Everything else worked straight away
Message 17 of 18
ryan.bales
Autodesk Support
Autodesk Support
I would leave feedback about it on the app store if i were you. Just so they can test it.
Ryan Bales
Message 18 of 18
OK, will do
