- Mute
- Permalink
- Report
There are several windows in Fusion 360 that cannot be resized, for example, the Export window depicted below. In this example, there are 4 file names that are too long to fully display. The fact that column width in the list control can't be adjusted doesn't help either.
There are other windows in Fusion 360 that have this limitation: Move to window, Change location. Interestingly, the Save As window IS resizeable:
One other thing, in the Export window, if I click the "Save to a project in the cloud" checkbox, the window height increases to accomodate the file list, which causes the bottom-right corner of the window to end up off the screen below the bottom edge of the display (obviously this is probably not an issue on larger displays). I had to hide the Windows taskbar just so I could get to the bottom-right corner, only to learn there is no resize handle anyway. Because of this, it would be much better if windows could be resized by any side or corner, which is standard behaviour in Windows, OS X and Linux. Resizing by just one corner is very clumsy—even Apple admitted it after years of forcing users to resize by just one corner.
