Cannot move any object due to Error: Position calculation failed due to initialization error
plwongah
plwongah
I tried to drag and drop another component file into my current design from the left panel. When trying to place and move the component, an error: "Position calculation failed due to initialization error" occured. I tried moving existing objects using the move command, but the same error occurs. May I know how can I fix it?
Steven_Gao
You can use the "Compute All" command below modify panel. Then you can move the component and the error should be gone. Refer to the attached picture.
Steven Gao
Fusion & Inventor Quality Assurance
https://www.autodesk.com/campaigns/fusion-360/insider-program
