Cannot move a line in a sketch
I have no idea why this is so difficult.  I have a rectangle.  I draw a line from the mid point of one side of the rectangle past the other side of the rectangle.  Then I want to move the line back so that some part of the line hangs off or extends past both sides of the rectangle.  Seems impossible.  There is no way to move a line once drawn.  I've been trying to simply move a line for an hour.
rohit.bapat
Hello @Anonymous
Can you please put the screencast for the issue? It will help us in debugging the issue and/or give a solution if possible.
My suspicion is that due to the coincident constraint at the first point you are not able to move the line. Can you please check if you delete the coincident constraint at the first point move works?
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Product Owner
g-andresen
Hi Mike,
I agree with @rohit.bapat
Please complete these and any future contributions with illustrated images or a meaningful screencast.
The best option is always to attach a file with references to the relevant place.
günther
