Cannot Find Drawing Templates
KneubaeckerS7UG4
KneubaeckerS7UG4
Hello
I have custom drawing templates that I use daily. Every day when I go to use them I receive a error notification saying that the template can not be found (I attached a picture). I have to then open the folder containing my templates for it to work for the first time. It is very cumbersome to do on a daily basis and it seems that there is a broken file path somewhere that doesn't allow fusion to see the templates right away. Let me know your thoughts thanks.
HughesTooling
I've had this happen as well. Odd thing is other templates in the same folder work first time, only have the problem with one template! @Phil.E  Any ideas on this?
Mark
Mark Hughes
Owner, Hughes Tooling
KneubaeckerS7UG4
Before making this post I searched the forums for anyone having a similar problem. I saw one post saying similar issues and that after awhile if not in use some of the templates might be looked at as "archived" and you have to reopen them to essentially refresh them. I use my templates daily though so I don't think that was the problem in my case. I also just tried multiple templates and on the first try the do not open without the folder containing them open as well. Appreciate the help.
Phil.E
This is a case where diagnostic logs should show some clues. The very next time it happens, immediately gather logs and please post them.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
KneubaeckerS7UG4
Logs attached. Thanks boys
ClintBrown3D
Hi @KneubaeckerS7UG4
Good news, this has been resolved in the November release of Fusion 360 (which should be available imminently)
More info here:
https://forums.autodesk.com/t5/fusion-360-support/november-2021-product-update-improvements-known-is...
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
KneubaeckerS7UG4
Works great now. Appreciate the fix!
