Cannot dimension to a centreline mark if the view is cropped.
vrpostcard
vrpostcard
Another drawing related error.
If a drawing view is cropped using the new crop tool, the end of the dimension that is referenced from the centerline mark will not display, leaving half a dimension mark.  If you dimension between 2 centreline marks the dimension will not display at all.  Dimensions work correctly on an uncropped view.
You can see in the attached video that when I dimension from the wall to a centreline mark, haldfof the dimension is missing, and then the next dimension does not display at all.  When I remove the crop from the view the first dimension displays fully.  I have to re-added the second dimension which then works without the view crop.
sayali_todkar
Thank you for bringing this issue to our attention.
We have created a ticket internally and are actively tracking its progress under FUS-193074 . Our team will work diligently to resolve it.
We appreciate your patience and understanding.
Sayali
SYNiMAK
I have noticed a similar issue when dimensioning with a cropped view. Half the dimension disappears. See attached image and video...Screenshot 2026-01-29 at 4.30.07 pm.png
