Cannot Create New Project
schmidtwoodworks
Message 1 of 30
schmidtwoodworks
When I try to create a new project I get the following error:  "Not Allowed PUT /communities/api/user/create for b78b90a9171f.1664285fd95".
I confirmed my license is up to date. Tried logging in/out to no avail.   Can anyone help me with this?
Dan
Replies (29)
Message 2 of 30
julia.paganucci
Autodesk Support
Autodesk Support
hi @schmidtwoodworks ,
thanks for posting! if you go to myhub.autodesk360.com and create a new project there, what happens?
thanks,
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
Message 3 of 30
Hey, I have the same problem. When I try creating a project via the web interface, I get a "Usage limits exceeded" error. Is the number of projects limited to just 8?
Message 4 of 30
julia.paganucci
Autodesk Support
Autodesk Support
hi @Anonymous ,
if you clear your local cache, are you able to create a new project after?
thanks,
Julia Paganucci
Message 5 of 30
I have the same problem, I tried clearing the cashed data. but no luck.
Message 6 of 30
jaybrown226
Community Visitor
Community Visitor
Same problem here.  Hoping this will get resolved. Cant archive, delete folders or create new ones.
Message 7 of 30
Hi - I have the same issue - I have followed the steps for a Personal Account - but get this error.
Please help.
Pete
Message 8 of 30
admaiora
Same problem
Not Allowed PUT /communities/api/groups/20190426190564401/status for b7a105deaba1.xxx-xxxxxxxx
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 9 of 30
Matthew.GreyES9US
Hi, I have the same problem.
Receiving this error message: Not Allowed PUT /communities/api/user/create for b7a1b05d7b93.16a92ec62a9
Message 10 of 30
admaiora
Please fix and solve it.
We can't do nothing on our side.
Admaiora
Message 11 of 30
Same "Not Allowed Put..." error, licence looks fine. I can save in projects already created but can't create or archive projects.
Message 12 of 30
Same here, I can't create it in software or in the web interface. Personal non-commercial license which I renewed, which I suspect as the year ticked is likely the culprit here. Please fix this.
Message 13 of 30
Same here, I just updated the free non-commercial license and now can't create new projects. Old projects work fine.
The "new project" feature in https://myhub.autodesk360.com/ returns the error:
"Not Allowed PUT /communities/api/user/create for ..."
I simply get a blue bar and "??" in the fusion 360 app.
Message 14 of 30
admaiora
I can't believe that after 4 months there is no solution or an explanation for this.
I see that message many times on customer account.
Admaiora
Message 15 of 30
Hi Julia,
Is there a solution to this issue yet?
I am having the same issue when creating a new project or trying to edit or archive existing.
Thanks.
Message 16 of 30
arladarla
Observer
Observer
Still no solution? I just got this error now after changing from the "hobbyist"-license to "personal use"-license.
Cannot archive or create projects 😞
Message 17 of 30
walrys
I wasn't able to save a new project simply because I had too many existing projects in my library (Personal license has a 10 project limit).
Had a clear-out and all is good, but attempting to rename or archive empty folders to tidy up the list also thre up this error.  A work-around was to archive my folders via the web interface:
https://myhub.autodesk360.com/g/all_projects/active
(You'll have to be logged in, obviously).
Hope this helps.
Wal.
Message 18 of 30
seth.madore
The "10 active projects" limit doesn't go into effect until January...
Seth Madore
Message 19 of 30
walrys
Heh, well at least I'm now prepared for it..!
Must have been a temporary glitch not being able to save a new project.
Deleting/renaming folders via the web interface works for me as a workaround to avoiding the error seen in the OP when attempting to delete/rename folders.
Wal.
Message 20 of 30
I also have this issue. I have returned to Fusion after a long break and updated my account as part of the update process. I can not create a new project even though I only have 2 existing/active.
