Message 1 of 8
Cannot Create Cylinder On Pre-Selected Surface
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Since the beginning, if you wanted to create a simple cylinder (or box), it was possible (or even expected) to first click and select the surface/face you want to begin it on, then chose the Create Cylinder command. This would then directly prompt for choosing the center of the new cylinder, on this pre-selected face/plane. However, for at least 6 months, this has not been working, and it results in very obviously buggy behavior. See attached screencast. This has been unaddressed and seemingly unmentioned across several updates. The workaround is to first run the Create cylinder command, then select the face. But it does impede usability in several situations.
