I'm glad using the archive file worked, thanks for the update.
From what I can tell, it looks like Fusion is trying to open the design from a crash recovery direct and failing. I suspect because there is an issue with the recovery file.
20170625T154732 I Begin: Opening the document: CNC_Assembly v23 at path: ***/Local/Autodesk/Autodesk Fusion 360/***/W.login/F/_CNC_Assembly.918c6632-d51d-4b5b-b31f-d4335e0685be.f3d
20170625T154734 I User chose to open the document from the crash recovery folder ThreadID: 13292, Function: OpenDocumentUtil::openFileFromCrashRecovery, Line: 337
20170625T154734 I Analytic--Top Level Open:***/Roaming/Autodesk/Autodesk Fusion 360/***/CrashRecovery/5068afd5176d4996b886c8e54af31254.backup
20170625T154734 E false
Function: Ns::DocumentImpl::makeByOpen
File: S:\src\Core\Neutron\Server\DataModel\Document\Impl\implDocument.cpp
Line: 410
Thread Info: [Name: Main], [Id: 13292]
Bug Alerts are usually indicative of subtle problems with the program or with data. Please log a defect if you can reproduce this work flow. Please mention BugAlert in the defect's description.
[Abort] - Show call stack information. [Retry] - Launches CER Dialog. [Ignore] - Continues program.
[Ctrl+Ignore] - Always ignores this alert in this session.
[Ctrl+Shift+Ignore] - Ignores all alerts in this session
20170625T154734 I The file ***/Roaming/Autodesk/Autodesk Fusion 360/***/CrashRecovery/5068afd5176d4996b886c8e54af31254.backup could not be opened. It is probably locked by another program. ThreadID: 13292, Function: Ns::DocumentImpl::makeByOpen, Line: 415
Line: 375
... usually indicative of subtle problems with the program or with data. Please log a defect if you can reproduce this work flow...
20170625T154734 I The path ***/Local/Autodesk/Autodesk Fusion 360/***/W.login/F/_CNC_Assembly.918c6632-d51d-4b5b-b31f-d4335e0685be.f3d is not a valid zip package. ThreadID: 13292, Function: Ns::DocumentImpl::makeByOpen, Line: 379
20170625T154734 W MessageBox Warning: Failed to open zip package ***/Roaming/Autodesk/Autodesk Fusion 360/***/CrashRecovery/5068afd5176d4996b886c8e54af31254.backup.
At this time, I'm not sure how to reproduce the issue from scratch, but if you have any suggestions or ideas, please let me know.
Either way, I'm happy you're able to move forward with the archive file.
Thanks again!
Nathan Chandler
Principal Specialist
