Can you export a fusion 360 file so that you can use it in Maya?
Hi I am a student trying to use Maya for 3d modeling for the unity game engine, I am personally much more versed in fusion 360 then Maya and I was wondering if I could export a fusion 360 file into Maya and then import the Maya file into Unity?
Any help would be much appreciated?
masa.minohara
Hi @Anonymous,
Thank you for posting! I believe you can use OBJ file for those programs. Please refer to this article for how to export files from Fusion 360.
Hopefully this helps!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
maruska
How do you adjust the quality settings of an OBJ/STL exported from the web portal?
tomo1230
Hi @Anonymous
I am using this Add-In.
 FBX Converter Pro for Autodesk Fusion 360
 https://apps.autodesk.com/FUSION/en/Detail/Index?id=4009665558731247469
Feature
1. Generate FBX file format(.fbx)
2. Quick process of FBX generate
3. Small file size
4. Control quality and size of generated FBX file
5. Choice of writing Normals in FBX
6. Colors and material
7. Unit option to scale model
Can reduce polygons!  Good!!
神原Θ友徳(かんばらΘとものり)Tomonori Kanbara -JAPAN-
この投稿が参考になりましたら、「いいね」を押してください。
この投稿で問題を解決できましたら、「解決策として承認」ボタンを押してください。
Autodesk Fusion 360 Certified User 資格認定
3Dモデリングによる3Dデータの活用法とデジタル・ファブリケーションの実践!
The method of utilizing 3D data by 3D modeling & Practice of digital fabrication!
https://ameblo.jp/tomo1230fly/
(http://blog.goo.ne.jp/t2com1230/)
maruska
There doesn’t appear to be a Mac OS version of that add-in.
Although I feel this should be a built-in feature to Fusion. An easy way to get models into DCC applications seems fundamental.
TrippyLighting
Not for a CAD application.
