can't split body
can't split body
calexpavel
Message 1 of 11
can't split body
calexpavel
I'm trying to split a body into multiple parts using surfaces but i get the error: "Error: Split9
Compute Failed. No intersection between target and split body"
https://a360.co/2LbfiPR
Replies (10)
Message 2 of 11
jeff_strater
@calexpavel, I don't seem to have access to that project on A360.  I get this:
You can always export the design to a Fusion Archive (f3d) and attach it here.
Jeff Strater
Engineering Director
Message 3 of 11
calexpavel
Sorry, i didn't check authorise download. Try this one please: https://a360.co/2C4C88Q
Message 4 of 11
TheCADWhisperer
Can you File>Export and then Attach the *.f3d file directly here?
Message 5 of 11
jeff_strater
Thanks, @calexpavel, I can export the model now, and can reproduce the problem.  We'll look into it...
Jeff Strater
Message 6 of 11
jeff_strater
OK, it took me a while (thinking slowly this morning), but I understand now what is going on.  That error is misleading.  It is not that there is no intersection between the body and the splitting tool, but that the splitting tool does not cut the body into two pieces.  This is a limitation/the nature of the beast for Split Body.  In order for Split Body to succeed, each Split has to divide the entire body.  In your model, if you try to split the body using this splitting tool:
The operation will fail, because there will not be two bodies that result.  Ideally, Split Body should allow the selection of multiple tools, so that you could split this thing all in one go.  You could do stuff like, define sketch regions that you want to cut that cut the body all in one go.
then extrude a surface:
and use that as the splitting tool:
which will trim out one section:
You can also, I think, use Boundary Fill to do this.  I need to think about that some more, and I'll try to create a video later today to explain that approach
Jeff Strater
Message 7 of 11
davebYYPCU
It’s easier than that,
Split body works with sketch articles,
(no need to extrude your cutter, fine for demo purposes)
selecting the lower three lines will get it done.
Might help....
Message 8 of 11
calexpavel
Thank you very much! Hopefuly in the future we will be able to select multiple cutting objects.
Message 9 of 11
jeff_strater
Agreed.  Just for our internal purposes, the issue for this is FUS-28349.
Jeff Strater
Message 10 of 11
bannister_lee
Observer
Observer
I also got that error today for a surface sweep that I was using as a tool to cut a solid body.   I discovered that for sweep's profile, a projected line is fine to use, but for the path, the projected line is not allowed.   Once I replaced that projected line with a curved spline, Fusion was happy.
Message 11 of 11
tonynicholls2
I too, had the same problem. My solution was to create a plane (offset) where I wanted to split the bodies, draw a shape to encompass the bodies on the plane, extrude the shape as a cut, then select and delete the unwanted parts. Then use the Create, Mirror command on the same plane.
