Can't sign in after signing out. Autodesk Identity Manager Error
quinton_lyonGX46Q
Message 1 of 11
quinton_lyonGX46Q
Not a new fault here on the forums. I can't sign in anymore. Fusion360 says to "Check your web browser to sign in" but fails when I click the button. Autodesk Identity Manager "closed unexpectedly".
Report ID is 727190233 and 727189273 and a few more from several retries.
Previous posting uninstalled the Identity Manager, not sure if I want to try that yet.
Replies (10)
Message 2 of 11
P-BvanWyk
Good day @quinton_lyonGX46Q,
Have you tried to reset your Fusion 360?
Please click on Accept Solution to help other community members solve their issues.
Also, consider giving a Like to the comments that you feel added value.
Kind regards,
Pieter-Ben van Wyk
Message 3 of 11
quinton_lyonGX46Q
Not sure what you mean by "reset Fusion". I tried exiting it and removing the Identity Manager from running processes. This I did a few times.
I didn't re-install it but after two PC restarts it is now working and I can sign in.
This is now the second time this same issue has happened, previously it took longer for me to get back to work.
Message 4 of 11
P-BvanWyk
I added a link to "Reset" on the above message with the steps.
Kind regards,
Pieter-Ben van Wyk
Message 5 of 11
quinton_lyonGX46Q
Thanks, I see the reset link now. I'll will try that next time, hopefully I won't need it again.
Quinton
Message 6 of 11
txk355
Observer
Observer
Hi I have the same error and resetting fusion didn't work either. Do you have any other ideas on how to fix?
Message 7 of 11
quinton_lyonGX46Q
No help really. I believe I re-installed Fusion but it may have been restarting the PC that did it. Have you tried the RESET option?
Sorry, I just reread you question, you did try the reset option.
Message 8 of 11
txk355
Observer
Observer
Yeah ive tried the reset and reinstalled fusion at least 3 times with restarts of the pc inbetween
Message 9 of 11
jerry_r
yeh, i have tried everything and i still cant get fusion to open, should never had signed out. been 3 days , reinstalled computer, fusion 360, identity manager, tried repair, tried reset and still the same pop up appears. beyond a joke now
Message 10 of 11
txk355
Observer
Observer
I found a solution. Go to settings>apps>installed apps then search Microsoft edge webview2 runtime. On the 3 dots on the left press modify and press on repair. This fixed the issue for me.
Message 11 of 11
jerryNYCB8
 Your  a GENIUS! Thank you so much for replying, that worked 100%
