Can't Set the GPU to visualise and render my models
daniel.waiger
Observer Observer
daniel.waiger
Observer
Observer
For an unknown reason, I can't make Fusion360 to utilize one of the 2 GPUs installed on the server (2*CPU: Xeon Silver 4210R) I'm running it on (Windows server 2019). I've been looking for a solution for 2 weeks, and saw what should be defined on the NVIDIA control panel to enable the GPUs (RTX A6000) when I run the application.
[GPU Information]
GPU Device: Microsoft Basic Render Driver
GPU RAM: 128 MB
GPU Driver API: DirectX 9.0
GPU Driver Version: 10.0.17763.1432
GPU Driver Date: 11/27/2020
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
g-andresen
GPU Rendering is not available in Fusion.
Fusion Renderings use the CPU.
günther
jhackney1972
As you mention, you need to tell the Fusion 360 application to use your Nvidia graphics card.
John Hackney, Retired
daniel.waiger
Observer
Observer
Thanks for replying.
I meant to the "live" render of the model, not the render module.
Any leads?
It seems like Fusion doesn't "see" my GPUs, no matter what I've tried (except reinstalling).
daniel.waiger
Observer
Observer
I've tried to do so, no success, any other way to do that?
Thank you!
jhackney1972
Did your Restart the server after you did the Nvidia Control Panel change?
daniel.waiger
Observer
Observer
at least once
