Can't Pin to Toolbar
debiWD4ZQ
debiWD4ZQ
Morning All,
I am struggling to pin shortcuts to the toolbar.
I go into the 3 small dots and it flashes up the tick boxes, then it comes up larger in the middle of my screen. when i try to mouse to it, it disappears.
After doing the recording for the screencast it appears that if the menu overlaps the larger box then i can mouse over to it, otherwise it disappears.
any help is greatly appreciated.
https://screencast-o-matic.com/watch/cF63Q3Yzcd
pawel.potyrala
Hi @debiWD4ZQ,
thanks for posting! The box with "Pin to toolbar" option should appear right next to the drop-down menu with available features. Have you tried to restore the layout to default already? The instruction can be found here: How to reset to the default layout in Fusion 360.
If this does not help:
  1. Does this happen for a specific workspace (i. e. Drawing) or for all the workspaces?
  2. Does this happen after you've unpinned the toolbar and moved it to a different position?
Thanks in advance!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
debiWD4ZQ
Hello!
Thanks for the reply
Restoring to default sorted the issue.
to answer your other point, it was happening in any work space.
Unsure about if i had unpinned the toolbar.
Thanks again.
consider this solved!
hello,
I have exaclty the same problem, reseting the view doesn't change anything. It's doing it in any workspace.
I didn't unpin the toolbar, it's still doing the same if i unpin the toolbar.
Latest Nvidia drivers (updated it today to see if it could change anything), latest Fusion version, windows 10 64.
