Can't install update or unistall Fusion 360.
dlugin2
Observer Observer
dlugin2
Observer
Observer
I have been trying few times but no succsess. I can't install update ot unistall Fusion.
Getting this error 'utf-8' codec can't decode byte 0xf1 in position 77: invalid continuation byte
RajkumarIlanchelian
@dlugin2 Please try below steps to install Fusion.
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
