Can't import igs file
Message 1 of 12
My IGS file size is 190 MB, i can't upload or import into Fusion 360. When I select my file using New Design from file, it starts loading but not working popup appear. Is there any way to upload an igs file of 190 MB?
System has 16 GB RAM.
Please help with the issue
Replies (11)
Message 2 of 12
Attached a image
60% of upload was done and not uploading further
File size can't be minimized
Anyone please give me a solution please
Message 3 of 12
TheCADWhisperer
Can you zip and Attach the file here?
Can you upload it directly via a web browser to https://myhub.autodesk360.com/ rather than via Fusion?
Message 4 of 12
I uploaded the file through My Hub which was successfully completed but now I getting a error "Max Attempts with no progress" when I create the design in fusion 360.
Screenshot attached
Message 5 of 12
I can't upload the file so I share you the link below
https://a360.co/2NatLuu
Message 6 of 12
TheCADWhisperer
You problem statement indicates importing of an IGES (*.igs) file, but the MyHub link is for a *.3dm file?
Can you post screen capture of where you got information that it was an igs file?
Message 7 of 12
Sorry for the late reply. I able to import both IGS n 3dm files, I think the previous file was corrupted.
Thanks for the reply and suggestions!! @TheCADWhisperer
Message 8 of 12
Hi, I have absolutely same issue with my 50mg stp file - cannot upload to new project - stuck in 60% same as your uploads. When I want open stp file thru "new design from file" fusion start to open file and after few minutes freeze and a I need to force stop program.
In two weeks ago I open same file with fusion without any issue, so can cause this last update???
Message 9 of 12
TheCADWhisperer
STEP (.stp) is not IGES.
Upload to your myhub.autodesk360 and share link here for others to experiment and see if they can reproduce the behavior.
Message 10 of 12
here is the file my college also try it and same issue with the file, I think something messed up with fusion during last updates...
//edit
Sorry I delete link because its not my file, if somebody from admin wanna see file and try yourself Ill send link to myhub via private message.
Message 11 of 12
TheCADWhisperer
I was able to open in Autodesk Inventor Professional - but not Fusion 360.
Message 12 of 12
Make sure you join/combine all your polysurface before importing into Fusion 360, otherwise import your bodies separately and then combine in fusion workspace. I figured out that my file wasn't imported because of this problem only. Once I separated my mesh bodies and then imported it is successfully done. Can you please check if this solution helps you out @Anonymous Thank you!
