Can't get reasonable cnc tool path for simple shape
jdubois31
Message 1 of 8
jdubois31
I have a simple shape of a cone on top of a cylinder and I can't get Fusion to generate a reasonable tool path. It won't cut to the bottom of the model. I even tried a second tool and operation but it creates an empty path. Any help would be appreciated. Design files attached.Screenshot Bad tool path.pngScreenshot bad CNC.png
Replies (7)
Message 2 of 8
seth.madore
Can you share your file so we can see your settings?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 8
jdubois31
I thought the file was attached? Did it not upload?
Message 4 of 8
seth.madore
That's a negative
Seth Madore
Message 5 of 8
jdubois31
OK, I will try again to attach the file...
Message 6 of 8
seth.madore
It's your "Offset" value in your Geometry tab. Set it to a small value, and Fusion will go outside the boundary you defined. See attached photos
Seth Madore
Message 7 of 8
jdubois31
Thanks, but why did that work?
Message 8 of 8
seth.madore
Because your Boundary is your part model. Setting it to a small value outside of that allows it to "see" the silhouette. Conversely, if you were trying to do a 3d surface (such as a mold), you would typically want to put in a small negative value so it would be guaranteed to hit everything required.
Seth Madore
