Can't Edit F360 Scripts (VCS does not open)
epeleg
epeleg
Did anyone else encounter a problem with editing F360 python Scripts?
When I try it pops a command windows that says something like "Installing Extensions" and then "Extension ms-python.python already installed" And that's it, try again and nothing happens restart F360 and we are back at square one (get the same message once).
I went to VCS and uninstalled the extension and tried again.
This time it said that it installed V2020.8.108011 and that's it... still did not open it to edit my script.
restarted F360, not it again tries to install the Extension and says that its already installed.
also tried to unsinstall the extention and install an onlder version or two but htis also did not help.
Any Ideas on what should I do?
Rushikesh.kadam
@epeleg can you try steps mentioned at https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Edi...
Rushikesh Kadam
If my reply was helpful, please give a "Like" or click the "Accept as Solution" button (or both)
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
JeromeBriot
@Rushikesh.kadam, can you update this note because actually it is possible to upgrade the Python plugin until version 2020.6.91350 (still better than the 2019.9.34911 version)?
Thank you.
