Message 1 of 21
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to create a coil for a type of mixer, 200mm diameter, 3 revolutions, 250mm high with a -10 deg taper. The coil is square sectioned, (2mm), and I have no trouble creating it but I cannot adapt the coil to create wider fins, 10mm at least.
If I offset the inside face of the coil, after 5mm the geometry fails.
If I try and sweep a profile from the bottom of the coil, (my preference as I can play with the profile shape), either it also fails or I get unpredictable twisting and edges.
Finally, I am suffering numerous crashes when either creating or editing coils, as happened when I was trying to record a screencast for this post.
Help would be appreciated.
