can someone pls help me with it?ive tried the fillet and the chamber option and either of those things work
maoz57125712
Message 1 of 8
maoz57125712
Replies (7)
Message 2 of 8
ltomuta
Does it work if you remove this radius (and any other like it that may not be visible in the picture)?
Message 3 of 8
maoz57125712
what does it mean remove the radious?
i think it'll just ruin the shape ,no?
Message 4 of 8
maoz57125712
ho and thank for replying 🙂
Message 5 of 8
jhackney1972
Please attach your model.  Open it in Fusion 360, select the the menu, then Export, save to your hard drive.  Attach it to a reply post using the attachment section.
John Hackney, Retired
Message 6 of 8
maoz57125712
thank you
Message 7 of 8
ltomuta
Message 8 of 8
jhackney1972
Your model that you attached only had a sketch for the area in question.  I extruded to outline "to" the other body hoping this is the thickness you wanted.  I have included the model with a .1 mm fillet which I achieve using a Sweep.  You can take the fillet radius up to .15 mm is you would like but it fails above that.  Model is attached.  Let me know if I can help further.
