Can not make a solid from a sketch
Message 1 of 9
I am new to fusion 360.  I am following the tutorials on how to get started from fusion 360 help.  For some reason once I have made a sketch, I can pull or extrude the sketch but it seems to  be transparent not like a solid even after having stopped sketch.  Cam doesn't want to process a transparent object from modeling.
Replies (8)
Message 2 of 9
jhackney1972
Please post your file so others can troubleshoot it for you.  With the file open, select File, Export and save it to your local drive.  Then attach it to your post.  When you ask a question about your file it always should be attached to your question because the reviewers cannot tell what you have done.  I cannot replicate your issue just from your description.
John Hackney, Retired
Message 3 of 9
Thank you very much for your response jhackney1972.
I have found the problem.
I have fixed it through using different settings.
Message 4 of 9
Hi, can i know how to resolve the problem? I had the same problem too. I cannot make it into solid drawing.
Message 5 of 9
jeff_strater
if you share the design containing the sketch, we can show you.
Jeff Strater
Engineering Director
Message 6 of 9
Here, i attached picture of the drawing. It cannot become solid. 2021-01-08.png
Message 7 of 9
g-andresen
1. SURFACE > CREATE > Thicken
2. Maybe : share your file
File > export > save as f3d locally  > attach it to the next post.
günther
Message 8 of 9
This is the file.
Message 9 of 9
jhackney1972
If you desire it to be completely solid, take a look at the Screencast.  You need to use the Solid Environment not Surface.
