can not delete project or open project folder error "You don't have required permissions to perform this operation."
tanat_boonpar
Message 1 of 11
tanat_boonpar
I create a project in fusion 360 and get error "Operation failed" or "Failed operation" someting like that. After that, I create another project and got 2 projects, one can delete and other cannot delete or open project folder and get error "You don't have required permissions to perform this operation." What can i do.
Replies (10)
Message 2 of 11
sutherland-
Hi @tanat_boonpar
Are you using the same account when logging into the web as well as F360?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 3 of 11
tanat_boonpar
Hi @sutherland-
Yes, I'm using the same account with both website and Fusion 360.
Message 4 of 11
sutherland-
Okay, are you the owner of the comiceLaboratory team?
Note, not the project, but the team owner.
Best regards,
Level  sutherland-
Member
Message 5 of 11
tanat_boonpar
Yes, I am an owner of comiceLaboratory team, And there is only me in the team.
Message 6 of 11
sutherland-
Have you tried to log in from another browser or device?
If yes, I would suggest you to contact support directly, they will be able to assist you if there any issues with the account itself.
Best regards,
Level  sutherland-
Member
Message 7 of 11
tanat_boonpar
Yes, I try to login website and Fusion 360 in another laptop, The result are the same.
And I use Fusion 360 Education plan that Autodesk doesn’t provide technical support with their free software.
Message 8 of 11
sutherland-
I do believe that you can contact support no matter what kind of plan you have vie web browser, since I have had a Education license prior as well and they helped me. Just try to contact support directly here.
Best regards,
Level  sutherland-
Member
Message 9 of 11
tanat_boonpar
How do you contact support?
I try to contact support but there is no contact option.
Message 10 of 11
sutherland-
Hmm, that is weird, maybe they changed something.
@jeff_strater could you please provide some assistance here?
Best regards,
Level  sutherland-
Member
Message 11 of 11
kodymatthews
Has there been any movent on this? I am having the same problem but trying to archive and active project that is not showing in fusion. i get the same permission error every time i try to do something with it.
