Can not delete desgn file although not referenced
HarrySatt
HarrySatt
Hi there
I have one design which was transfered from EAGLE. Now I would like to delete this but I am not able to.
I can see that it is not used and does not use any other design in the screencast. What am I doing wrong? Cant figure out.
regards, Harald
MoshiurRashid
Hi
Thanks for posting. Would you please share the design file with us or, attach here?
File> Export> F3D
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
HughesTooling
Was the design ever used in another design as a linked or derived part? If it was and the design that referenced it still exists then the reference will still be there in the version history. Unfortunately Fusion has no tools to view past references in other design's history and no way to remove old versions from a design's version history.
The only way to fix this sort of version history problem is to download the top level design then upload to a new project or folder then delete all the old designs. You'll need to delete the designs in the correct order, top level design first.
Mark
Mark Hughes
Owner, Hughes Tooling
HarrySatt
Hi
for what ever reason the problem disappears. I today was able to remove the problematic file. Yesterday I created a new project in EAGLE by copying all files to a new folder, renamed the folder and created a new FUSION file. Today two problems disappeared. I can delete the oder file with th eother name what I was not able to do yesterday and my FUSION link from EAGLE seems to be stable.
lets see. Thanx for help.
regards, harald
