Can not create a new Project
af_Maniac
Message 1 of 10
af_Maniac
Hi i need help with my Fusion, i can not Create a new Project in my Fusion 360 (2.0.12392). When i click on new Project ill see it for 5 seconds then it is gone in Fusion.
But when i look online in my account ill see all the Project wich i tried to create!
But iam somhow the not the owner in Fusion of it i can only see a Project wich is shared for me!
Can someone help me out?
https://screencast.autodesk.com/Embed/Timeline/21f6dfc5-6032-493a-929c-bfea7db2bcd9
Replies (9)
Message 2 of 10
pramod.pk2XX6G
@af_Maniac  Thank you for your posting in the community!
You are on the latest version of Fusion 360. Can you please look at this article and see if any of this applies to your situation? Click the hyperlink for the article - Unable to create or save a new project in Fusion 360.
Please keep me updated!
Thanks.
Message 3 of 10
af_Maniac
I have checked that already, and iam a Single User there no Admin Settings and my Licenses are all available for me so what can i do? I hope that an Autodesk admin can fix that in my Profile.
Message 4 of 10
pramod.pk2XX6G
Hi @af_Maniac
May I know your Account login email ID?
Pramod
Message 5 of 10
af_Maniac
sendet it via Private Message
Message 6 of 10
pramod.pk2XX6G
Hi @af_Maniac
Thanks for sharing the email ID. I found that you have single-user storage and you don't have a Fusion team.
Can you just give it a try now, by creating a new project in F360? Please let me know the result.
Pramod
Message 7 of 10
af_Maniac
After a Relog on Fusion it seems to work now, iam now the owner of the new Project, what did i do wrong? Could i fixed that by myself?
Message 8 of 10
pramod.pk2XX6G
Hi @af_Maniac
Awesome, Great to hear that.
I have done changes to your Single-user-storage here and it seems to be working well.
In the future to avoid these types of situations, I would suggest you use the Fusion 360 team hub.
If a Single User Storage hub is being used, then signing up for and transferring the data to a Fusion Team Hub will be necessary.
  1. Use the Fusion Team Hub Onboarding tool to create a Team Hub.
  2. Transfer the existing projects into the Team Hub by following instructions in the same onboarding link or see How to transfer Fusion 360 projects from Single User Storage to a Fusion Team Hub
Pramod
Message 9 of 10
af_Maniac
I see ill try that but i see the new Project again for a short time can check that iam the owner then it is gone after 5 minutes i just waited not long enough....
I will try to setup a Team and will look if that helps.
thanks
Message 10 of 10
af_Maniac
After setting up a Team Hub it is working beautifully thx for the advice !
