Can no longer hit escape to cancel edit in dimension tool on Mac
gman-r
gman-r
Not sure when this started happening, but when I add or edit a dimension I can no longer hit Escape to cancel the edit. It will not exit and revert to the previous or default value as it should. Clicking away doesn't work either. I've been suck in situations that the only way out is the click CMD-Z to undo.
jeff_strater
I do not see this problem.  Can you record a screencast of it?  The only advice I can offer is just basic stuff:  restart Fusion, make sure your ESC key works in other applications, etc.
Jeff Strater
Engineering Director
gman-r
Ok. Restarting fusion seems to have cleared it up. The escape key definitely was working fine and did work in some places in fusion such as the save dialog, so it seems the design environment got into some state where is didn't handle escape at all anymore. Couldn't even cancel out of drawing a line either.
