Can i share Sheet metal Rules with another user?
ArlinHorstSigns
ArlinHorstSigns
I'm the main user of Fusion 360. We use the Sheet metal model fairly often. If someone else wants to use the sheet metal module. I have to screenshot my settings, and then manually put them all back in on their computer.  Is there a simpler way to export the rules and load them on another users computer
TheCADWhisperer
Why not Export a blank sheet metal file with the desired Sheet Metal Rules?
jhackney1972
You can share sheet metal rules only by sharing a model that contains the sheet metal rules contained "In this Design".  Once you have this the process is pretty simple to share the model and have the user save these styles to their sheet metal rules library.  This will make the rules available for all sheet metal models moving forward.  The Screencast will show the process.
John Hackney, Retired
ArlinHorstSigns
Thanks, Hadn't thought of that.
ArlinHorstSigns
@jhackney1972   Thanks that was super helpful!
