Hi @szymonszewcjr ,
Thank you for raising this.
At the moment, Fusion does not provide a built-in option to customize UI font weight, boldness, or label size within the application. The UI typography is controlled by the application design and currently cannot be adjusted independently.
However, you may be able to improve readability using a few system-level options:
1. Adjust display scaling (recommended)
Increasing system display scaling can make UI text easier to read.
2. Check OS accessibility settings
Some operating systems offer accessibility settings that increase contrast or adjust text rendering, which may help with thinner fonts.
Regarding your question about reverting to an older UI or version:
Fusion is designed as a continuously updated cloud product, so older versions of the application are generally not supported or available to roll back to, including for personal use accounts.
That said, feedback like yours is valuable, especially regarding readability and accessibility. I will make sure this feedback is shared with the team, since UI changes can affect users differently.
If you’re able to, please also let us know:
Your operating system and version
Your display scaling setting
Whether the change appeared after a recent Fusion update
This helps us better understand how widespread the behavior may be.
