Buggy Solver on Sketch Dimension Change
TheCADWhisperer
Consultant Consultant
TheCADWhisperer
jeff_strater
thanks, @TheCADWhisperer , that's a bug, certainly.  Thanks for the screencast and the model.  Really helps us look into this.  I'll send this right over to the solver team.
Jeff Strater
Engineering Director
jeff_strater
on further review, this is not a sketch solver problem at all.  If you edit sketch2 on its own, you can change that dimension to any value no problem.  The problem occurs in the Thicken feature.  For some reason, it fails to compute at some values where it computed before.  It seems like a sketch issue when you edit the dimension outside of the sketch environment, but that's just because the edit is one transaction, and if any downstream features fail, the entire transaction fails - in this case the dimension edit.  I'll submit this as a Thicken issue.
Jeff Strater
TheCADWhisperer
While they are looking - I also had a lot of trouble with Thicken relative to the arc size in the sketch.
I did not use the arc size that I wanted as it would not Thicken.  (I understand not Thickening to where it would be zero.)
