Buggy Render workspace
silvio3105
Message 1 of 8
silvio3105
render workspace is buggy.
- I can open only two images
- I cannot pan or rotate model
- Fusion sometimes uses .tif, sometimes .tiff while exporting.
- After a while I get white workspace, no model (check image below) and it does not recover - reopening file does not help, reopening file and changing workspace does not help too, only app restart helps.
- Sometimes environment resets from dark to light color style(not only if it crashes but if app gets "killed" via task manager)
Specs:
Windows 10 Pro x64
R7 260x 2GB - check below for driver info
16GB DDR4 3200MHz
Threadripper 1950X 3.6GHz
Samsung EVO 860 250GB
Fusion 2.0.14337
DirectX 9 driver(I've used DirectX 11, same problems). With OpenGL I have big problems in Design workspace.
Here's video
https://youtu.be/M5FW7hvLawE
Here's another video where I'm trying to open device model. It seems Fusion cannot handle small assemblies....
https://youtu.be/uypPt9dQ3Ew
Thanks!
Replies (7)
Message 2 of 8
karina.harper
Autodesk Support
Autodesk Support
@silvio3105
From a quick look, I have a feeling that render is going very slow rather than 'not loading'. It may have the same root issue as the file not opening - would you be able to share the problematic file?
Does render work as expected in a simple file, like a box?
Cheers,
Karina
Message 3 of 8
silvio3105
I left it for 45-60mins and it did not move.
CPU and RAM usage was very low, almost zero.
Where I can send file(s)? File from video have links with other models(PCBs etc.). Do I need to export them too with main file?
Thanks.
Message 4 of 8
silvio3105
Can you share e-mail so I can send download link for whole assembly?
Message 5 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @silvio3105
You don't need to send any individual parts - if you export or share link from the main assembly they will all be included.
Karina
Message 6 of 8
silvio3105
Okey, where I can send assembly?
Message 7 of 8
karina.harper
Autodesk Support
Autodesk Support
Either post it here or feel free to PM it to me if you'd rather keep it private.
Karina
Message 8 of 8
karina.harper
Autodesk Support
Autodesk Support
@silvio3105
So on my mac I am having no issues rendering your. model, no problems with the render environment either. I am suspicious that in your video your CPU usage is at 0%. You aren't having any problems with other applications?
Can you try the solutions in this article?
Additionally, can you screenshot this dialog and share it here?
  1. Go to the ? Menu at the top right of Fusion.
  2. Select 'Support and Diagnostics' >> 'Graphics Diagnostic'.
Cheers,
Karina
