Bug: Reproducible crash when adding external component
jarrod.smith
jarrod.smith
Assemble -> New Component -> External [don't select a file] -> OK.
Crash every time.  I'm on Win10.
Phil.E
Thanks for reporting. I see your crash reports, but I'm having trouble reproducing it and might need a little help here.
When you say "don't select a file" do you mean a folder location or a parent in the assembly? In either case, Fusion will not let me use OK until both of these fields are filled. Can you describe this a little more please so I can understand what's happening, and most important how to get into the state you describe.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
jarrod.smith
2 things:  First, when I wrote this bug report I thought the feature did something that it does not do (I thought it was how you *import* an external component to a project).  So I misunderstood what the dialog is for and thus the language I used in the report is confusing/inaccurate.
Second, I am starting to think this is file-specific.  I can't reproduce it with a different file than the project I've been working on.  And with this specific file, I cannot get this feature to NOT crash the program no matter what I choose for the the parent, or the folder location.
Let me know how you want to proceed.
Phil.E
So if I understand fully, you have a particular design that crashes when you attempt to create an external sub component.
It sounds like it might repeat in debugging. Can you share the design so I can test it? (file > share public link) or send me a PM with the link.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
jarrod.smith
Yes, we are on the same page now.
Here is the link:
https://a360.co/3lFwiiM
Phil.E
Thanks. The crash is repeatable using your model. I'm sending it along with a report about the crash.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
